JD 50 rockshaft housing
Sippriver
New User
I have posted several times recently about my 3 point that will not lift any weight. I think I found the problem.
Rockshaft housing has a crack when the fluid goes from pipe to lower port that feeds powertrol.
Are those easy to find in junk yards?
thank you
Well that sounds like a weird one. Wonder if it had water in it freeze ? or if someone set the pressure too high and caused the problem ?
Should be able to find one. Any junk yard with a model 50 likely would still have that housing as you would rarely ever need one. Post where you are from and maybe some will have phone numbers for junk yards near you ?
we are in Massachusetts, but if the salvage yards ship I dont care where the housing come from.
thank you
