JD Compact Utility Line Forum?
Dave H
Is there a forum comparable to this one that is on compact utility JD's. Both my front hubs/final drives leak a 6 inch puddle on the floor after working. The tractor has 264 ours on it. I do not know the history. It is a 1026R (2012)
Thanks
Dave H,
You could also try TractorByNet.com to research this common CUT Problem (John Deere). My 2520 had one side leak very early on while still under warranty thankfully as it took four returns to the dealer to get it fixed. Sure is disheartening to see a relatively new tractor have that kind of problem. Hope you get it fixed.
