Wildride47
I hope someone can provide some advice about replacing the rock shaft on an open station 2555. I had a park brake shoe Fall apart and and removed the rock shaft and completed the repair. Now it’s time to reassemble and I have a question about the rock shaft cylinder linkage and how it runs agains the cam follower spring arm above the ring gear. Does the. Cam follower run on the out bound end of the linkage or is it inserted into the gap between two sides that support the rolller. The assembly manual does not clearly identify how these two components fit together.
Greg
Greg
