TDJD
I?m looking at a power-trol for my B. Will a 1949 B power-trol work on a 1943/1946 B? And is $40 a good price?
Thanks.
If the 43'/46' B has Power-Lift, just remove if , get new gasket, & bolt on Power-Trol ; Power-Trol's used on "48" & newer A, B, G's thru "56" 70's.. Check serial # on power-trol box , if PCV 67906 or up, it uses newer couplers & dummy plugs ,, there much better...
That Power-Trol uses older couplers & dummy plugs ;[see pic] not a good as newer style, which are more of a break-a-way,
