John Deere B antifreeze
kRM1976
Went to change the exhaust manifold because the other one was junk, when I pulled the back two studs antifreeze came pouring out. Is my head cracked?
No
Through hole into water jacket
Brass push rod tubes directly under hole use a zip tie to feel for tube and establish how much to thread new stud bolt in ( not to far )
USE CAUTION not to disrupt push rod tubes
High temperature silicon new threads
