J D 4115 help please
Friend has a JD 4115 compact tractor.
Problem -Steering cylinder leaks, JD says they have no kit., Hydraulic shop says they can not get kit.
Does anyone know where you can get kit or is there a replacement fix with a different cylinder>
Thanks for any information. Bob
Wonder if HYD. shop even tore it apart ? One would think it might just have some sort of "normal" seals in it ? My lift cyl. on the F725 lawn mower was all welded together. I cut it apart in the lathe. Matched up seals locally and then had it welded back together. I did not trust my welds. Had a pro do the welding.
Yes they did. They said all they could do was put one o-ring on it.
No kits were available. Good shop as I have had them get hard to get kits before. Said all there sources had none.
They also said it was metric. We are going to compare it to some other small cylinders and see what we can do.
I just thought maybe someone else had encountered this and had a solution.
