2040 hydraulic remote
Ive got a 2040 John deere that does not have any remotes on it.
How i install remotes? Where do they hook to? I only need one remote so i can use a hydraulic cylinder for top link
Thanks
What you need will depend on the serial number of your tractor as the three cylinder 2040's were built with both open and closed center hyd. systems. You can go the factory route with a valve from a tractor salvage yard or you could just use a regular valve like a wood splitter would use. Tom
I checked your previous post where you posted your 2040 serial number. Your tractor has closed center hyd's. You can mount any utility tractor CC scv or as Tom stated a valve similar to controlling a log splitter/FEL Pictured below is supply line(key 3) for scv that attaches to priority valve close to hyd filter & factory return went into side of rockshaft housing.
. Go to a salvage yard and scoop all the SCV parts from any closed Center Deere Utility tractor .
The free online parts book is supposed to cross reference common parts used on several
Models .
