Re: 1010RS Gas won’t run
John T
01-23-2019 10:05:08
One common cause is points that are burned or pitted, oxide coated, or not adjusted properly, look at that FIRST.
If a light not overly abrasive clean/buff/polish of the points (some run a dollar bill through them) and adjusting gap doesn't help, if they are badly burned or pitted a points file may get you going, but they need replaced.
It happens that "new" condensors are often bad out of the box !!!
If all that fails work through my Ignition Troubleshooting Procedure linked below and report your findings.
http://www.ytmag.com/cgi-bin/viewit.cgi?bd=farmall&th=5745
John T
