Heated fuel filter?
You could install the newer-style spin-on filter assembly with heater as used in the newer tractors, Stanadyne FM100.
The link below will download Stanadyne info, look on .pdf pages 9 and 10 (paper pages 7 and 8) for part numbers, note item "Q", the heater which is interchangeable with a blank cover.
ebay is a possible source, or check with you local diesel pump shop.
Heated filter
Mix some #1 fuel in with the #2 for cold temps. I forget how much we added to the furnace fuel oil tanks ?
