What is the proper adjustment technique for setting the throttle rod length between the throttle control arm (base of the steering column) and the spring on the governor?
This is rod 1 of 2.
I have swapped out the steering column and the max throttle setting screw and the length of the throttle rod are way out of adjustment.
I do have a digital tachometer for setting max engine rpm.
There have been numerous detailed posts/threads on how to set the governor to carburetor control rod as outlined in the JD B Service Manual page 110-10-3.
I have made this adjustment and now I need guidance on setting that first rod.
I'm open to suggestions as to setting the max engine rpm as well.
I monitor this forum daily and thank so many for their helpful comments as I restore my late uncles 1950 JD B.
Richard
This is rod 1 of 2.
Richard
