2040 fluid capacity and maintainance
I was wondering how much
Oil and hydraulic fluid goes in a 2040 John deere?
Does anyone have the filter numbers?
How do you change the fuel filter?
Thanks
Here you go . And before the manual police come by and issue a citation for an infraction of not getting the manuals I?ll just say it will Answer a lot of your questions if you get the manual
Untitled URL Link
AR75603 is hyd filter part #. Don't get alarmed if 41.2 qts of fluid doesn't drain out because it's difficult to get ALL the hyd oil out of the hyd system. Correct way to check hyd oil level is with engine idling.
SVcummins
I noticed in photo you posted of tractor fluid spec's it stated 2040 built in Dubuque,Ia. which I sure thought all 2040's were built in Mannheim, Germany. I sure thought I picked up 2040's & other JD utility tractors of that era at the Gulf port in Houston that had been unloaded from a ship that came from Europe. I know Tractordata agrees with my thoughts.
(quoted from post at 01:04:56 01/16/19) I was wondering how much
Thanks
Which 2040? There is a three cylinder and a turbo four.
1-800-522-7448 for the operator’s and service manuals . Parts book is free on the JD web site .
Tx Jim maybe someone got the wires crossed I
found that list on the jdparts maintenance
information page
