Hydraulic fluid filler cap on 2040
Does anyone have a picture of the factory hydraulic filler cap that screws into the cast housing above the the 3 point hitch?
Would a regular steel plug used in plumbing work?
Thanks
<img src = "https://encrypted-tbn0.gstatic.com/images?q=tbn:ANd9GcTqPMDr4-Av92K0hmfoat9K2Ptqfsfg0GYRgFia4CSRDT1rM5Ybjg">
It's a vented plastic plug that seals with a gasket. Thread size isn't given on the DEERE parts site.
AL38083, about $30 at the dealer.
(quoted from post at 02:57:26 01/16/19)
Thanks
No because as Bob mentioned cap needs to have a covered open breather hole so as to let air into sump area &amp; let moisture out when oil gets to operating temp/
