Stroby
This tractor is a 2001, I have had it since 2005. It has 435 hrs on it and has never failed to start except for one time when I needed to replace the battery. This past Saturday, I used it for 3 hrs while snow blowing snow from my lane and several other lanes here In Illinois. It ran fine. I had added diesel fuel treatment to the tank before using it for the 3 hrs. It had @ 1/4 tank of fuel in it, plastic tank, but today I added @ 2 gal of winter diesel fuel to the tank and it will not start. Turns over fine. I checked the battery to see if the cranking amps were too low, and decided that I needed a new battery. Bought one, installed same. Cranks fine, but won't start. It has glow plugs and a heater. I have had it plugged in for 4 hours and used the glow plug function for up to 45 seconds on one attempt. Nothing. I went to town and bought a can of starting fluid from tractor supply. I have NEVER used that stuff and know one has to be careful about the amount sprayed. I removed the filter elements, sprayed a short burst into the canister and it started up.....but died after running out of either. I gave it a very short blast, it started again....stumbled....I gave a short blast...it ran....then stumbled... I quit. What happened since I shut it off two days ago and now? Any suggestions?
