Jd 50 dash light bulb replacement
youngin
Can you replace the bulb in the fixture or do you need a whole new fixture?
Is that the original or an after market socket? Bulb should be replaceable. Bulb part number for original is AB 2599 R. A #67 bulb will work.
Looking more carefully, I see it's the original socket. The hood is usually rusted on and takes a strong "wiggle" as Bob suggested.
Thanks for the quick reply. I sprayed it with some wd 40 last night. Wasn't sure how aggressive to get.
Thanks
