Wishbone update
SVcummins
Had to borrow a ball joint press to push the pin through took a 2 foot ratchet to get enough force to push it out but it finally came
Cliff I beat on it with the air hammer for 30 minutes and it didn?t wiggle I couldn?t believe how tight it was
This might be a stupid question but bare with me. Keep in mind my welding experience is stick and mig all self taught. Your welds appear to be on the surface of the break. Is there any welding through the cross section of the break? Is that what your heating for? Are you brazing or something to create a weld all the way through the break. Otherwise I don't know how that could hold. Thanks. Paul
I?m not doing the work . He just has it tacked together so he can clamp it and then he?ll vee it out and weld
