2140 hydraulic pressure
Mvolk18
New User
Hello I have a Deere 2140 and was wondering what the hydraulic pressure should run at the remote. I measured it at 2100 psi and while everything is running fine my loader feels a little weak moving hay. Also when I checked the filter bypass there was just the sleeve and no spring?? Steering, hi/lo, pto, 3 point all work good
Tractordata shows 2466 psi(170 bar) for hyd pressure.I was unaware JD 40 series hyd's stand-by pressure was set much over 2250 psi. Increasing stand-by pressure 300+ psi will give some lift strength to loader
Thanks. So if my understanding is right the adjustment is on
the bottom of the hydraulic pump and just keep bumping it up
until I?m around 2400ish at the remote?
Also noticed when the tractor is warm there is some mist in the hydraulic fill hole. Only when it is warm, I checked for that when cold and there is nothing. I destroked the pump the mist is still going. Compared with my 4240 the hydraulic pump on this 2140 is a good bit louder as well. After reading some horror stories on these forums it sure makes a man worry
Rockshaft valve or seals are beginning to leak,partially stroking the pump giving it a rattling noise.
