4020 powershift loader question
Richard55
I recently purchased a 1965 4020 powershift and am going to take the loader off my 4010 and install on the 4020. On the 4010 I feed a 3 spool valve from the port in front of brake pedal. The line feeding this port from the priority valve is a 5/8 line all the way to the 3 point rock shaft. On the 4020, this line is 1/2 all the way. Are all 4020s like this or just the power shift. the 1/2 seems to small to feed my 3 spool valve. Thinking about feeding the 3 spool valve from the 5/8 line that supplies oil to the priority valve. any thoughts on if the 1/2 line would supply enough oil to my 3 spool valve without restricting to much oil flow. seems odd that they would put a smaller line on the 4020. thanks for any help you could give me.
I think a loader with ind hyd valve attached to rockshaft hyd supply line on a '65 4020 with powershift trans will operate fine. I know the 158 FEL I installed on a '66 4020 with PS trans with hyd valve attached at same RS supply line does. I even returned oil from loader valve to trans case because tractor owner didn't want it routed to hyd filter.
Attaching a hyd valve in front of pressure(priority) valve defeats the purpose of the pressure control valve which is to give priority hyd oil pressure to steering & brakes.
I have had a 158 Loader plumbed into my 1965 JD 4020 Powershift for better than 30 years at the fitting below the brake peddles. I have never had an issue with not having enough oil (pressure or volume).
HELLO, haymaker-2, i see your name pop up on this post so i might might be hitchiking, but i wanted to get a response to you concerning the 2010 prestolite distributor parts. THANKS for your message, it looks like what i was looking for, BUT i could not pull it up on my ebay. i guess i-m too old school to know how to properly message you or pull up this seller on ebay etc.. etc... turning 70 this year. i don't get on my computer but about once a week. been working 51 years at DEERE dealer. THANKS AGAIN
(quoted from post at 02:08:52 01/09/19) HELLO, haymaker-2, i see your name pop up on this post so i might might be hitchiking, but i wanted to get a response to you concerning the 2010 prestolite distributor parts. THANKS for your message, it looks like what i was looking for, BUT i could not pull it up on my ebay. i guess i-m too old school to know how to properly message you or pull up this seller on ebay etc.. etc... turning 70 this year. i don't get on my computer but about once a week. been working 51 years at DEERE dealer. THANKS AGAIN
copy and paste the link below to your browser and it should come right up.
https://www.ebay.com/itm/PRESTOLITE-DISTRIBUTOR-IGNITION-POINT-INSULATOR-F227-F244-F245-Flathead/253811622047?hash=item3b185a009f:g:3p8AAOSwYSBbcHc6:sc:USPSPriority!14167!US!-1:rk:1:pf:1&frcectupt=true
