What is the "pedal" that disengages they hydro pum
On a Deere 2010, I'm missing that pedal that goes up to the operator platform and that you step on to disengage they hydro pump for cold weather starting.
I can't seem to find this part or search for it, I must be using the wrong terms.
What is this part called and what is the part number?
Many thanks.
Grouse
I don't recall it being much of a "pedal", but it's shown with the hydraulic pump, Key # 28.
<img src = "http://jdpc.deere.com/pimages/RWP5/RWP5828________UN01JAN94.gif">
#T15353 (Hi crop and row crop utility)
#T15189 (Row crop)
T15189 Lever shows as NLA in the JD catalogs. T15353 is called Actuator, and it shows as "NLA, check with dealer for options" when I checked that number.
What did you determine you distributor was, a Prestolite?
Thanks guys.
I went to the farm yesterday and I noticed the pedal/lever was missing. Not sure it was ever there, but I'd never started the tractor in temps that cold.
Jim, I totally forgot yesterday to look at the distributor to see if it has that tag. I was in such a hurry, I had to grind my way in through deep snow, so I jumped on the tractor and plowed the driveway and then put it away. I didn't think of looking until I was driving back home (105 miles).
I'll look next time, but thanks for remembering!
Grouse
