4430 Plastic Return line from from front pump
Anyone know the part number for the plastic line that runs from bottom of front pump to right side of trans about 6' long? Had some difficulty today at parts counter. Thanks!
You can check it out yourself anytime you need parts. Go to John Deere Parts Homepage. Put 4430 in where it asks for the model and it will open the parts catalog for it. 3 choices. You will need to know what your transmission is and tractor serial number for one transmission, where two of the 3 choices are, if I looked at the right line.
If it is like the 3020-4020's Deere supplies a generic line that is way to long leaving you with a bunch of extra to deal with. I buy the plastic line at my auto parts store and reuse the fitting from the original. Take a flaring tool and heat it some with a torch and melt the line enough to flare it. Practice a few times with the old line and you can get it perfect. Tom
