Mnethercutt
I’ve just finished reassembling my 1010 and am concerned that the clutch is not going to fully disengage. I haven’t tried to drive yet or even put the tractor in gear while running, but I cannot adjust the pedal to have the 3/4 inch free play. Adjusted as far as I can, I have about 1.5 inch of free play. If I press the pedal down and engage the pto, I can spin the pto but I hear the clutch spinning. When I reassembled the clutch, I just put everything back together and bolted the pressure plate down tight. I used the shaft to try and keep the disc centered but just want to make sure I haven’t screwed something up before I burn up a clutch disk.
Thanks!
Thanks!
