JD 430 Question
Bobl1958
I picked up a nice little 430. It had no battery, but I am thinking it would have a 6v with Positive Ground? Would that be correct? Thanks - Bob
That is what they were originally. What it is now is anybody's guess. Alternator or generator?
The generator if still there should have a tag unless missing or rusted over saying the voltage. Alternator should be 12V. It is possible somebody threw a 12V generator on it.
(quoted from post at 10:34:59 12/31/18) The generator if still there should have a tag unless missing or rusted over saying the voltage. Alternator should be 12V. It is possible somebody threw a 12V generator on it.
"The generator if still there should have a tag unless missing or rusted over saying the voltage."
To add to what "NY" said, if a Delco generator 9as it would have left the factory with), if the original 6 Volt unit, it will have a "black" tag.
If, by some chance it had has been "upgraded" to a 12 Volt Delco generator, it will have a "red" tag.
A six volt battery won't blow anything up. Odds are slim that someone slipped a 12V generator on there.
What is the make and model of the ignition coil and is there a ballast resistor ?
Here is a picture of the generator. I would assume it to be original, but who knows.
"[b:654c4848f0][i:654c4848f0]I would assume it to be original[/i:654c4848f0][/b:654c4848f0]"
Take a look at the [b:654c4848f0]GENERATOR[/b:654c4848f0] diagram below.
Note the subtitle [b:654c4848f0]Delco-Remy No. 1101859[/b:654c4848f0].
The number indicates that it is the correct OEM generator.
It could possibly be the generator originally installed at the factory.
Hope this helps.
It appears to be a 6V. Thanks to all for your input. There was no battery in it, but I was pretty sure on the Pos ground as well as the 6v, but had to buy a battery and didn't want to get the wrong one. Thanks again - Bob
"[b:654c4848f0][i:654c4848f0]I am thinking it would have a 6v with Positive Ground?[/i:654c4848f0][/b:654c4848f0]"
Reviewed the [b:654c4848f0]<a href="https://www.amazon.com/John-Deere-Tractor-Data-Book/dp/0760302286">JOHN DEERE TRACTOR DATA BOOK</a>[/b:654c4848f0] in the [b:654c4848f0]John Deere Model 430[/b:654c4848f0] section on page 142.
"[b:654c4848f0]Ignition . . . six-volt Delco-Remy[/b:654c4848f0]"
Take a look at the [b:654c4848f0]Lamps and Ignition Wiring[/b:654c4848f0] diagram below.
Note the battery is POSITIVE ground.
Hope this helps.
