2510 diesel
About how much is this tractor worth with a blown engine? Unknown hours but many. Bought new on our farm. Everything worked fine when engine went out.
Block bad and cannot be overhauled. Might put new engine in depending upon cost.
Assuming that the cylinder head, injection pump, electrical, etc. can be "harvested" for parts probably at least 2,500 dollars and if wide front end with good sheet metal including fenders then easily 3,000 dollars. A good running 2510 diesel should bring 6,500 dollars even if the paint and tires are fair at best.
Just sold a good running 2510 with wide front end and a gas engine with a JD loader and got 6500.00 for it so maybe one with a diesel engine may be worth a little more.
If it has a good Deere wide front and good sheet metal (including the panels that say 2510) the $2500 figure is a good place to be. Post some pics as I might be interested in it. I have a 630 to haul to WV this winter spring and could haul yours on the back trip. Tom
. 2510 and 2520 in particulate are in demand . Zippy machine with a 276cu” Dubuque engine . 85HP no problem at 2200rpm.
(quoted from post at 10:03:56 12/31/18) Diesel engines are easy to find for that 2510.
Very. I found one in a construction cart, was running a compressor. Paid $400 years ago, 276t. Still running.
