4430 Steering Valve
Late model 4430 has started leaking oil under dash. I took one out before but can't remember if the dash had to come out or not. Correct me if I'm wrong but I'm thinking pull the hood, steering wheel, and cowls and such to remove. Any pointers appreciated!
Pull the steering wheel,remove the lines and pivot bolts,,it will drop down out with out removing the dash.
Actually it was a piece of cake. I have better luck taking apart than going back together though! Had part of cowl already off but had steering valve out in less than an hour with a headlight and short breaks...Was going to carry it to local repair shop but wondering if check valve replacement is part of standard rebuild or should be requested?
