I have my crankshaft, block and head at the machine shop. Camshaft is mailed off to Hill Crest cam repair to be brought back to specs. New pistons on the way. Powertrol and final drive is off and currently dismantling the transmission. I have all shaft but the bottom out and its a pill. All the gears look really good except the two under the left side metal cover behind flywheel. The top one was scrap, 6 or 7 teeth were sheered off. dont know how the guy was running it at all. Crazy because it was an old injury and someone left that gear in after a repair because no metal teeth was found in the bottom of cover . Those two gears will get replaced. I pryed on all the shafts while they were in and found minimal play. Bearings were surprisingly good to be sitting in water for who knows how long. Believe ill just replace all bearings while there. The upper shaft that separates, has a gear that slides over another gear has a little play when coupled and not sure how tight it should fit. Very big project but hoping for a sound 630 for the future. If I can manage to get it all back together. Its seems to be a little more complicated than the 430 we just finished.
