I have a John Deers 310C with two hydraulic hoses coming out near the back hoe controls in the rear. They have female quick connect fittings on them. I have traced the hoses to an aluminum block mounted on the frame near the front of the right rear tire. This aluminum block has a flipper lever that seems to be a switch. I traced lines from the pump and the supply line runs up into the loader control area and then comes down into the top of the aluminum block. There is a large hose that also comes out of that block that goes straight to the controls of the backhoe. One of the hoses that comes out of this block goes straight to one of the hoses that has the quick connect on it. The other quick connect hose goes back to tie into the filter. I am assuming that this set up is for a breaker, clam arm, or compactor. I am trying to hook up a log splitter to the backhoe bucket so that I can spit wood and load at the same time. I bought a 3-point splitter and bolted it to the backhoe bucket then ran hoses from the auxiliary hoses to the splitter. The aluminum block flipper switch doesn"t seem to do anything and I can"t get more than a steady stream to come from either one of the hoses There is no high pressure. The flipper switch does not affect the backhoe, loader, stabilizers in any way. I thought that the quick connect hoses out the back would be to run something other than the backhoe. Is this aluminum block a priority valve? I looked in my repair manual on how the hydraulics are plumbed and it doesn"t show or refer to this aluminum block. I have the splitter control valve mounted on the rear panel near the backhoe controls.I have plumbed one quick connect to the inlet and the other to the outlet with the other two ports going out to the splitter. I have reversed the inlet and outlet thinking that I had them reversed but that changes nothing. Can anyone please shed some light on this subject. I can take some pictures if that would help.
