Jd 50 water pipe
youngin
The upper water pipe has a hole. Does it just pull apart? Seems pretty stuck. I have it unbolted at the engine but it won't let go.
Thanks
It's a slip fit - an o-ring at each end. They get stuck pretty tight. Wiggle and tap.
May have to heat it to burn the o-ring out ? IIRC there are different pipe sizes depending on serial numbers. K & K tractors used to sell the odd size tubing to make new replacements from.
