Re: Advice on a 4020 with a slipping PTO
tim s
This must be a power shift?? the pressure is check with a test port on the clutch operating valve (left side) it should be 165PSI
Syncronize shift, want to check pressure on PTO engaging bearing , make sure pressure is right and engaging PTO
That is rarely a problem, but having the fingers on the clutch set correctly is,,if they are not right it will let the PTO bearing pulse and wear the o-ring seals quickly.
