I replaced the clutch on a 71 model 4020 last year with the
synchro shift trans. Had the flywheel refaced and used the JD tool when installing the pressure plate. He has only used it with a square bale baler and a 14' bush hog. It has a 2 stage clutch and the main clutch is holding fine but the PTO clutch is slipping so bad the bush hog will almost stop spinning. There is a inch of freeplay in the clutch pedal,is there anything else I can check to put him back to work? This is a 90 something HP tractor and I would have thought it would not have had any problem pulling a 14' bush hog.
