The Famous Grouse
Hi guys.
Question about points and condenser in 1965 Deere 2010 gas. The tractor runs OK, but there's a miss at idle. I'm thinking it may be time to have a look at the points/condenser. I have not replaced these since I bought the tractor in the summer of 2014 and I use it much more than the previous owner.
As a note, I replaced the plugs last August and they are correctly gapped. Qustions:
1. I have some maintenance records and a receipt that says the points were replaced in 2013. Only points are listed on the parts receipt, no condenser.
Just given the amount of time that has passed, should I assume both points and condenser should be replaced and order new parts before I tear into it?
As a note, the tractor stays up at my hunting farm so it's 90 miles from my house. In general, I prefer to have parts with me if I reasonably suspect they will be required rather than getting things taken apart and then having to leave everything until I can return with parts.
2. I see often repeated on this site the need to buy "quality" ignition components. Where do I get the good stuff for my Deere?
3. As long as I'm there, I have no idea when the cap and plug wire were last changed. Change these as well? Or only if the idle miss fails to disappear with new/properly gapped points.
Many thanks.
Grouse
Many thanks.
Grouse
