Console 4020 SCV question
Scott 730
Location
EC MN
My new to me 4020 has a 158 loader with factory 3 spool valve on back of right side loader frame. Loader valve is fed from #2 SCV. I know, not ideal, but has likely been this way for over 30 years. Tractor has factory #3 SCV also. The issue is that the loader will barely move when the flow control on #2 is set more than about 1/2 way open. Have to dial it back to about 1/4 open to get movement. I haven't tried it yet in the other SCV's. Why is flow restricted in #2 when over 1/2 open? Thank you.
(quoted from post at 07:40:31 12/09/18)
(quoted from post at 19:51:44 12/08/18) The flow control knob my be off 1/2 turn witch will do that
Ditto
Moved the knob 180 on the shaft. Seems to have fixed it. Thanks again. The knowledge on this site is invaluable.
Thanks for update. I'm glad you got repaired that easy. I agree that there is a vast amount of knowledge on this forum. I've learned a lot since I've been a member.
