Company Logo Shop Now
TractorLinks.com
Gear box question
deeretails
12-06-2018 16:03:51
I think I know what this is for, but seems to be a piece missing. Can any of you help me out.
third party image
third party image
third party image
third party image
third party image
deeretails
12-07-2018 08:14:47
 Re: Gear box question in reply to deeretails, 12-06-2018 16:03:51
Mystery solved, there was a stub shaft pushed into the 540 side. Managed to get it out and it fits right on the standard PTO shaft.
third party image
third party image
jd adict
12-07-2018 09:12:20
 Re: Gear box question in reply to deeretails, 12-07-2018 08:14:47
yes that looks better, now if you were planning on useing it the rule of thumb was to put a short pto shaft onto the end of the utility transmissions and then put the speed changer onto that. this helps eliminate some exessive torque on a long nose utility pto and breaking the ears off. we all have one of those that have been welded up, dont need any more.
i have never seen one on but question if a short pto shaft like on a rowcrop utility will fit onto a utility and then the speed unit because there is limited room with the big drawbar supports.
let us know or post a picture when you get it mounted.
Tim S
12-07-2018 07:22:28
Looks like you could turn it around and reduce 1000 RPM to 540 RPM...of course you would need to take the Horse power used into consideration...this gear box looks sturdy..
deeretails
12-07-2018 07:12:30
JD & Mike, I think there should be an adaptor piece between this box and the transmission. But I've no idea what it should look like. Love to see a picture or reference to it on a parts page.
jd adict
12-06-2018 19:49:59
its a dubuque powershaft speed changer. 540 to 1000 rpm.
yes missing the shield
nice option.
Mike M
12-07-2018 04:24:20
 Re: Gear box question in reply to jd adict, 12-06-2018 19:49:59
Wouldn't you need something to connect the two 540 male ends together ? Or did some of those have a removable stub shaft on the tractor end ?
