slant dash crank cover
curtkane
New User
I am desperately looking for a crank cover for a 40 B slant dash. I believe it would be a lights only because I dont want the starter ring. Can anyone help with this quest
If you don't want a starter ring then there is not a crank cover. Which I am assuming you really mean a flywheel cover ?
no I dont mean the flywheel cover. its the crankcase cover also has the breather pipe. I believe the lights only version dose not have the starter mount ring
If there was such a thing (which I do not know if there was or was not) it would be rare as hens teeth ! They may of just used the regular crankcase cover with some sort of offset mount for the breather ? Maybe the breathers from the cover with the starter mount would unbolt and fit onto the regular cover ?
i'm not sure if there is a special cover for light only version or if they used the same cover as the hand start. I know the breather offset works. I bought a 40 slant dash with hand start in the 80s and I got a electric start cover for it and converted to electric start. the breather switched over ok. Unfortunately Y no longer have the other cover. I have heard that ether cover will only fit a 39 or 40 tractor just don't know if the slant dash or regular hand start can interchange for those years It would be nice if they do.
Sounds like you need cover #B700R , fits unstyled B's and early styled B's. Should be a common part. If you can't
locate one , give me call at 573 535 8952. Tom Ziegler
(quoted from post at 12:28:46 12/03/18) I am desperately looking for a crank cover for a 40 B slant dash. I believe it would be a lights only because I dont want the starter ring. Can anyone help with this quest
There seems to be some confusion as to what you are looking for, so here's a link to the parts catalog (in .pdf format), post back with the part number of what you need.
http://jdpc.deere.com/jdpc/JDPC/attachments.jsp?associatedPc=PC0330.pdf
Thanks to Bob for the parts book link. Curtkane This will be your bible !
I think you are looking for a crankcase cover. For your tractor should be in serial # range 60,000-95,999 B1622R is listed for lighting only for that range. Some close comparison will need to be made to the unstyled parts book to see if it fits those ? also check gasket part numbers.
thanks bob for the parts list. after looking at it it appears you are correct mike, the part number is b1622r. now its trying to find it. ibet it is a rare one.
Thanks for all your help. Coming up with the right part number will certainly aid in the search. Merry Christmas all.
