johndeeregreg40
The spring connecting the throttle/ governor linkage is worn out and therefore the throttle control lever moves loosely before
start up. There should be tension on that lever at all times which is not the case with mine. I haven't been able to find a
matching spring in any hardware or tractor supply store and I was wondering if you guys had to replace this spring and where
you found one that works. Thanks!
Greg L.
Greg L.
