JD Belt Pulley 4010/4020 Tractors
I have a rear belt pulley assembly 1000RPM, my tractor side housing has part number R34594 on it. According to the parts book, that is suppose to fit a 4020. Also the parts book also lists for a 4010 T13328 as the tractor side housing.
Can anyone tell me if there is a difference in the mounting between a 4010 and a 4020.
Seems that the 4010 bolt holes are vertical from each other in a up and down manner.
The housing that I have, seems to have a stager in the up and down alignment of the mounting bolt holes.
Did Deere in their wisdom, change the mounting between the two tractors. I suspect I have a pulley for a 4020 and it was
sold to me as coming from a 4010.
Any thoughts would be appreciated.
R34594 isn't shown in 4010 parts catalog so my guess is that part won't fit a 4010 although the parts photo for T13328 appear to be identical in each parts catalog.
I tried again with no luck. Someone else started a small thread about them a little bit ago. I posted my pictures in that thread. It's on page 6 now if you want to see them. The way it looks I'm not the only one having problems posting pictures lately. I read posting pictures is easier on modern view but when I tried I was told my login is no good.
I'll attempt to upload photo for you. Upload seem to take a little longer but here it is.
Thanks Tx Jim. That's one of my pictures. I
recognize that foot. I just tried it again
and my phone keeps timing out before
anything uploads.
Just my luck, I probably have boughten the model for a 4020, I have two 4010?s a 61 and a 63. The 63 Dad bought new, it has a 4020 motor. We had a 4020 that I put a Detroit 6V-71 in, so put that take out motor in the 63. The original 4010 motor is sitting in the corner of the shop ever since.
Would still like to find the 4020, lost track of it. Traded it for a 4850 mfd.
Bohemian32,
I will attach a picture of the parts book showing them, it happens to be laying on my desk. I am the one in the last post about them that posted pictures of the repainted one. I have two of them, if you need me to measure anything or take better pictures for you to compare to let me know. I about bought one before I had these two that was cheap enough but it did look different through the mounting as you say and he said it's for 4010. It was $85 if I remember right so price was right but Dad only has 20 series tractors.
yes thank you, I saw that page on line last night, the housing numbers are different between the 4010 and 4020 pages.
I am thinking that I have one that fits a 4020, as the bottom bolt holes on mine are wider and my 4010 are straight up and down, vertical
