Bohemian32
I have a rear belt pulley assembly 1000RPM, my tractor side housing has part number R34594 on it. According to the parts book, that is suppose to fit a 4020. Also the parts book also lists for a 4010 T13328 as the tractor side housing.
Can anyone tell me if there is a difference in the mounting between a 4010 and a 4020.
Seems that the 4010 bolt holes are vertical from each other in a up and down manner.
The housing that I have, seems to have a stager in the up and down alignment of the mounting bolt holes.
Did Deere in their wisdom, change the mounting between the two tractors. I suspect I have a pulley for a 4020 and it was
sold to me as coming from a 4010.
Any thoughts would be appreciated.
