My H coolant hole treads are stripped. The plug will get almost snug then gets so loose you can turn it by hand. It is leaking a 4-5 inch puddle a day. I got to get this fixed.
I found some other threads on this that recommend putting a reducer in it with another plug inside of it. I'm not sure if I should use some sort of water resistant epoxy or JB weld? Should I try brass or metal?
Maybe there is a better way?
