I restored a 41 H a few years back. Entire engine was overhauled, bored .060 due to scoring. Always started easy, often on the first spin of flywheel. Secret formula for my H was no throttle, choke on, as soon as it fired immediately take choke off. The engine has truly never been broken in like it should be, unfortunately it sits most of the time in the barn. Early summer I put it in a parade and had it running for a couple hours. Back to the barn it went for a month. A friend came over and wanted to hear it run, literally started on the first spin. Sat for about three weeks and now all it will do is run for a few revolutions. Almost every time I spin the flywheel it will pop but won't stay running. Occasionally it will give me what seems like a mini backfire from the air cleaner. I have a nice blue spark from both spark plugs even from about a 1/4 inch away. Gas tank has fuel, if I open valve on bottom of carb bowl gasoline comes out. I can't understand how it can run so nice one day and not at all the next. I feel like it is not getting enough fuel but what can happen to a carb in a matter of weeks? The occasional mini back fire makes me think the timing is off but how can that be when I never touched it? The magneto bolts are good and tight, nothing has moved. My next step is to remove the carb and give it a good inspection. I had it running for about 30 seconds today by constantly turning the choke on then off, on then off, until eventually it quit. I can't understand how it can run so nice one day and not the next.
Any suggestions?
Any suggestions?
