Hello all: I'm trying to figure out what type of pto my late S/N 430U has...a transmission operated or continuously running one. That would seem simple but it had a cracked bell housing and was removed/had a cover installed so I haven't ever seen it "right". Now I have the cover off and can see what the inner shaft is doing, and it doesn't make sense according to the operators manual.
This below is all with the tractor in neutral at slow idle. The manual states for a trans operated pto, to engage it you push the clutch and move the shifter to the left (as you're sitting in the seat). Okay, that works and I get a fast spin, assuming would be 540 at working speed, so far so good. But when I clutch and move the lever to the right to "disengage", when I release the clutch the pto shaft is still turning, though much more slowly...like maybe 50-60 rpm. The only time the pto is not turning at all is with the clutch depressed though the manual seems to imply it should stop when disengaged. Althougb this then would imply a "continuously running" setup, the manual states that you move the shift lever to the RIGHT to engage it, and mine clearly engages to working rpm when I move it to the left.
So is mine a trans operated type and there is something wrong because I cannot get the shaft to simply come to a stop when it is disengaged (i.e. some shifter fork broken or some clutch adjustment needed); or is it a continuously running pto and among other things I don't know left from right?
Thanks for any help
Thanks for any help
