Simplicity717
New User
Hello everyone,
This is my first post, but I have been lurking for a while now.
Long story short, the engine builder who rebuilt our diesel 4020 engine (ten years ago) didn't do it correctly, and the front timing gear popped off, allowing the valves to make acquaintance with the pistons haha. I installed all new components (timing gear, pushrods, etc.) had the head milled/inspected. Everything it put back together, timed correctly and it fires right up.
The issue I am having is that the engine smokes a little more at idle than it did before, and it smoke a lot more on acceleration (then clears up at constant RPM). I have tried loosening each injector and each one makes a difference (so it is running on all 6), one injector had to be replaced with a new one too. Any thoughts on this?
The other issue I have is it doesn't seem like any oil is making it to the top end. On any other engine you would see the oil running off of the valvetrain components, etc. On this one there doesn't seem to be much if any. The rocker shaft is aligned on the pin and the hole that I think supplies oil seems free. I blew air into it and I could her the air in the oil pan area. Any thoughts on this?
-Will
-Will
