420 Water Pump Shim Washer
CPeter
I am replacing the water pump on my 420 and the shim washer was missing. Can anyone give me an idea as to how thick it is? I can machine one the right thickness if I knew what it was.
Thank you.
Peter
<img src = "http://oi63.tinypic.com/2ccl89c.jpg">
Parts catalog doesn't show a "shim washer".
There's Key #14, called a "slinger", still available from DEERE (A4282R). MAY even be rubber, NO dimensions are given by the online parts system.
Item #4 is the Shim Washer it is a M3048T and is still available from Deere for $1.99
See fig 90-15-13 in Service Manual SM2019 for location.
Dimentions are Outside Dia 0.750 in
Inside Dia 0.344 in
Thickness 0.024 in
Thank you for the dimensions. I will machine one this afternoon. Cheaper than trying to get one ordered and shipped online, although at $1.99 pretty reasonable.
Peter
