Usx-36 carb float
Put a new float in less then three years ago and it?s bad already. The floats are warped and rub agents the outside of the bowl. You can?t bend the arms then it rubs on the inside of the bowl. Has anybody have had this problem before? Got the float from John Deere. Looks like the local carb shop has the same float. Wouldn?t be so bad if the float didn?t cost so much!
