I have a JD350B that has the reverser lever on the dash. It has been hard to move and would typically loosen up a bit after use after sitting for a couple of months I used it again this weekend and it was exceptionally hard to move the lever. It was a two handed job to slide the thing and hardly loosened up at all. It seems to work fine with the exception of the effort to move the lever. What are the likely culprits? Could it just be a bad cable? I am guessing that I could just unhook the cable at the reverser and see how it moves. Where is the reverser and how do I gain access to check and or replace the cable?
thanks
thanks
