John Deere Belt Pulley Attachment
I was at auction and picked up a bunch of belt pulley attachments......I have one marked as John Deere: the part number on the right angle housing is T13326T JD...it looks like a 1000 pto spine that the unit would slide onto with 4 bolt housing Flange....it has a steel pulley on it with a 8 1/2 inch face and 12 inch diameter.....By the part number can you tell me what this attachment fits on? and Is anyone Here interested in it I am In MN......Thanks, Kevin
Look like this? I was told my dad bolted this one to his 4010. I don't think it was done very often but it was before I was born. It's been sitting in the barn since I can remember.
Kevin,
I have two of them, this one I'm attaching pictures of I bought 8 years ago or so, and went through it and repainted it. The second one I took apart has issues inside that need to be dealt with before running it, glad I did pull them apart to verify that.
If you look in the 4020 Operator's Manual they do talk about them in two sections, how to install them/check oil, and then the speeds to run the tractor to achieve belt pulley rpm's.
From what I've been told/read there are two types. The ones that fit the 10 series New Generation tractors, and then ones that fit the 20 series. Something about how the bolt housing/spacing fits over the PTO and bolts to the tractor. Don't quote me on it but that's what I remember.
I will attach 3 pictures that show the part #'s on mine, and by the # you gave it matches up. I know you cannot get the shims anymore that go between the housing's, one the one I need to fix I need those so I hope I can find someplace to get them, as it sets backlash as far as I can tell.
Where are you in MN? I'm in SE MN, I may be interested!!
I am located 30 miles north of St. Cloud......I need to go down to Harmony, MN in the next couple of
months.....I could bring it down when I go to Harmony.....What would you give for it?
Kevin,
I am not far from Harmony at all, have family that lives there, I think you should be able to email me now, in the lower right hand corner it should let you email me and we can talk price there. Thanks.
