smadjuster
New User
I am thinking of buying an old JD400 Backhoe, or at least I think that's what it is. Serial Number is 4219DF01320921T. The thing is a mess. No engine cover or radiator. Front weight at the tip of the hood is broken in half and the half is missing. Engine and front of tranny covered in oil/dirt. Valve cover removed, starter detached with some wear to flywheel teeth visible. Engine will not turn over and manifold has been filled to the brim with oil (I assume to protect it against weather - but water is heavier than oil!) Hydraulics appear decent, with a couple of cylinders leaking. Some hinge pins will require replacement. Front wheel bearings are probably shot/ wheels wiggle when I pull on them. Injector pump is covered in fresh oil/diesel.
Guy is asking $850 for it which is less than scrap value, I think?
I have no problem replacing a short block (if economical) and can eventually get to the rest of the issues. But can anyone tell me anything about this backhoe, since I an a total nube to this kind of equipment and know nothing about it. Thanks.
