I have a late s/n 430U (5 speed) I'm
currently steward of, and I'm not sure if
its a design flaw or just bad metal on
the original part but contact with the
shift guide over the years has slowly
been wearing a groove in the shift lever
shaft to the extent I'm afraid it'll snap
off this winter during plow duties.
I got a replacement shaft and new bushing
and snap ring, and also a OEM service
manual, and from the somewhat vague
manual description it READS like it may
not be necessary to remove the trans
cover and pull out the forks in order to
just replace the lever...just put the
trans in neutral position, pop the ring,
pull out the old lever and drop in the
new one.
My concern is the service manual shows
doing all this with the cover/fork assy
removed, and I'd hate to try
pulling/replacing the lever with the
cover in place as-is and hear various
detent balls, springs and other bits go
rattling down past the gear set into the
depths of the transmission. Does anyone
know the truth on this? Thanks for any
sage guidance!
new one.
sage guidance!
