158 loader cylinder reseal
Scott 730
Location
EC MN
Any tips or tricks before I work on my leaking lift cylinders? Looks pretty straight forward from looking at the parts book. Mother Deere is sure proud of their seal kit. $96 and change per cylinder. :shock:
Take outer snap ring loose, then push guide in to remove inner snap ring, might have to remove a ridge from the inner ring, if not clean it up good before installing the new seals.
(quoted from post at 23:16:24 10/01/18) Any tips or tricks before I work on my leaking lift cylinders? Looks pretty straight forward from looking at the parts book. Mother Deere is sure proud of their seal kit. $96 and change per cylinder. :shock:
You will be surprised how hard they will pull apart. Most likely you will need a tractor to pull the cylinder out of the barrel once both of the snap rings are removed.
I did one of ours. Should of done both at the same time. Other one started leaking from the rod seal some. I forget how I pulled it apart ? but I do remember having to mount the rod end back on the tractor to hold it good enough to get the packing nut loose. I also think a cheater bar was needed on the breaker bar. I stood it upright when putting it back together. Used a rope from a rafter to lower it down IIRC. Tried to carefully push the Vee packing in with a small screw driver but still shaved a little off of one vee.
My only tip - don't wear your Sunday bibs and tee shirt. I think that is about the nastiest job I've ever undertaken. Just when you think you have it completely drained, it will prove you wrong. I've been inside a lot of stuff, but most of it won't squirt you like a hydraulic cylinder will, ha.
There's a sign on the front door of the local Deere dealer that says something like - "All hoses and cylinders must come in the BACK door".
Looked at Baum's website. Their price is about 30% of Deere. Deere's kit shows 7 pieces included. Baum's has maybe only 3 pieces. Are all the pieces in the Deere kit always needed? Will the 3 piece Baum kit do the job? Loader currently works fine. No damage. Just old age leaks showing up. Thanks.
