need to rebuild 2510 seat
730virgil
I have 2 2510 tractors both of them need seats rebuilt I have been told it can be a big pain to do so.
where do I look for directions?
The Deere service manual has the directions. For parts I have been buying the kits on Ebay. They have all the bushings,rollers,washers,cable and the wind up spring for $102. If they are worn enough you will need the side plates and some other parts as well. Not cheap to do but well worth the results. Tom
I have done a couple now, not bad. You might check You-Tube. Also, take pictures as you disassemble. Good Luck. Paul
