I posted on here a couple of says ago about my John Deere M having a leak that I thought was the front engine seal.
Tractor hadn't been run in 4 years. Got it fired. Had a leak at the front of the tractor that I thought was front engine seal.
After i got the hood and grill off i can see it is not the front seal it is the hyraulic pump. I have run the tractor off and on for the last couple of days. Leak is now down to just a drip every now and then.
What are the odds of this seal in the hydraulic pump to completely stop leaking?
I know I should probably get the pump off and replace the seal. Just wishful thinking.
Thanks.
Thanks.
