4020 24 to 12v conversion
Looking for ideas on where to install the extra starter solenoid when doing the conversion.
For those that have done this, where do you normally install it.
According to JD under the dash on LH side.
I make a small metal bracket and bolt it onto one of the intake manifold bolts in behind the side panel. It is out of the weather and you do not see it sticking out. Some people put the inside the dash. I have seen them some very odd and nasty looking places. Tom
The official DEERE kit conversion comes with a little angle bracket to mount the solenoid to the circuit breaker bracket.
<img src = "http://oi66.tinypic.com/24kwoqg.jpg">
I put them under the cowl on the left side, drill and tap 2 1/4" holes in the steer valve frame..Use a 4430 alt. pulley to keep your nut from hitting the fan..an Iskra starter works well
