photo of MT rear
marlin54
forgot to add the pic so here it is
If you are talking the two square/rectangle looking spots below where the TOM arms are - I have no idea. I never had anything attached to mine or found any reason for those to be there.
"[b:654c4848f0][i:654c4848f0]I never had anything attached to mine[/i:654c4848f0][/b:654c4848f0]"
Same for our three 1951 MTs.
Maybe allows same axle housing to be used on Lh & Rh side of tractor. Maybe same axle was used on another machine, like an industrial one. Maybe to hold it in place while machining. I dunno!
Yep, axle housing M991T is used on both sides of the tractor. In fact, a whole lot more than just the housing is common.
Trivia: Did you ever notice that the Rh & Lh rear fenders on a 5200, 5300 and 5400 tractor are identical - just assembled using different holes.
Each separate part number in the parts system costs money!
